Re: Hotpoint DWF70P THERMOSTAT
AL10=
Check heater
Check heater cut out
Check pressure switch connections 11-14 heater supplied via these
check wiring and connections between module,pressure switch and heater if yopu have supply through heater it could be the relay on module.
Make sure all filters are clean as there is a sensor which will operate if they are blocked,supposed to be self cleaning 😕
Plus give all connections onto the module a tweek and the thermistor one too.
BG
