Hotpoint DWF70S AL02 fault after fitting drain pump
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint DWF70S AL02 fault after fitting drain pump
  • #46332
    Simon46
    Originally AL05 Drain pump sticking and drain hose holed leaking down back into base of dishwasher. fitted drain pump and hose complete. Difficult to get pump off due to clearance of drain hose to items under sump. Removed base plate tipped on back and removed pump and drain hose. Now customer complains that cycle stopped halfway thru, first time out full of water and end didnt show, just lines on LCD as if reset pressed. i called round started quick wash completed ok. Cust opened door closed again after cycle had finished and AL02 appeared on display.
    What have i done?
    S.
    #288962
    robstech
    AL02 = Valve or connections
    #288963
    franz
    Re: Hotpoint DWF70S AL02 fault after fitting drain pump
    check heater – although AL02 relates to valve its usually the heater
    Franz
    #288964
    Simon46
    Now worked for a week customer came downstairs in morning as drainpump has been running all night. Checked base dry no water floatswitch ok. LCD has scrolling figures. Unplugged,plugged back in LCD now fine and quickwash cycle completed ok.
    Wish i hadnt started this one. 😥
    S.
