Hotpoint DWL DEA602S fills, drains and error code
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint DWL DEA602S fills, drains and error code
  • #74539
    Washdisher
    Customer reported having filled sump with salt, however it worked once after this.
    Currently on start up;
    initial drain
    fills
    drains
    salt, rinse aid, wash and end lights flash
    Have checked cont across overflow protection, heater, circ pump all ok
    Forgot to look at side tank and wonder if there is some kind of flow meter like Bosch.
    Any help much appreciated
    #391955
    Re: Hotpoint DWL DEA602S fills, drains and error code
    Can you recheck that model number, means nowt to me. :con:
    Washdisher
    Hi Jim,
    That’s all I’ve got, taken from side of machine.
    #391957
    ???? Nothing remotely like that on Partfinder. 😥
    You must be reading the wrong number,
    Here is the full list from Hotpoints web site.
    Dishwashers
    Go through all ten pages and you will find nothing like those numbers.
    #391958
    Washdisher
    FDM550P.R
    it’s still not in the list you directed me to, but it’s close to one of them.
    #391959
    The R will possibly a factory rework. The number you gave is the type, not the model number.
    Are you in the trade, if you are then you should apply for trade access, then you will have far more information at your finger tips. 😉
    #391960
    Possibly knackered the main pump with the salt, those lights are a poor flow indicator, either a blockage or the pump is goosed.
    #391961
    Why don’t you apply for a trade account Washdisher as it appears you may well be in the trade?
    #391962
    Washdisher
    Hi Martin,
    I will, thanks
    Derek
    #391963
    iadom wrote:
    Are you in the trade, if you are then you should apply for trade access, :
    Did you miss this Martin? 😉
