Hotpoint DWT10, Not heating
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint DWT10, Not heating
  • #35339
    moscow1
    Can anyone help
    I have a Hotpoint DWT10.
    The machine has hardly been used.
    It seems to run normally apart from the water does not heat up.
    There seems to be no voltage at the element when running.
    The Thermostat is closed circuit when cold so I guess this must be OK.
    I have checked the water level switch connected to the little hose and it seems to be opperating OK. Continuity in One direction when unpressurised and continuity in the other when pressurised.
    Any Ideas would be appreciated.
    Must be something daft that I have not tried.
    Thanks in advance good folks.
    Moscow πŸ˜€
    #246131
    Re: Hotpoint DWT10, Not heating
    This has the infamous Bit100 series contol board, which is prone to falling over if smiled at. If you are certain that the heater is sound, the PCB will be your problem.
    P/no C00097481 if you intend to go ahead with the repair yourself. Be sure of your diagnosis, as PCB are non-returnable under any circumstance.
    spares@ukwhitegoods.co.uk will get one for you promptly.
    moscow1
    The machine worked perfect until I transported it between houses.
    So was moved around on it’s side in a car.
    Are these boards that sensitive?
    What is the best way to test an element just in case.
    Thanks πŸ˜€
    #246133
    moscow1
    Having another mess.
    At the end of the cylce the Delicate Light flashes on and off. Does this mea πŸ™‚ n anything.
    #246134
    Transporting it on its side may not have helped.
    Can you give us the number of the flashing light from left to right?
    If you have to ask how to test an element perhaps you should not be attempting to do so in the first place. πŸ˜‰
    Do you have a Meggar or a multimeter?
    moscow1
    Yes I have a multimeter.
    I can do most things so should not be a problem to test.
    The lights are arranged like this
    It is the rightmost light marked delicate
    7th light along.
    #246136
    That is a heater timeout fault. The heater in this machine should be visible inside the tub. If it is then that element is not as prone to failure as the later internal tube type heater.
    I would suspect the control module TBH.
    moscow1
    Is that the C00097481 PCB that penguin45 mentioned.
    The element is visible inside the tub.
    If so I can get for around Β£25.00 ish which isn’t too bad.
    The machine is not very old so is worth replacing
    Thanks for the ongoing comments folks.
    Really appreciated!
    πŸ™‚ πŸ™‚
    #246138
    Part number is actually C00143207. If you send an e-mail to spares@ukwhitegoods.co.uk with full model details you will get all the info you need.
    nightstalker3188
    I’m having the exact problem described….
    Has anyone found out if this is the pcb board or if it is the heating element…
    Just want to find out if it is worth calling HP to come out and fix it or if I can attempt this myself…
    Unit is out of warranty… would hate to pay a huge call out if the fix is an easy one,,,,
    regards
    Rob
    8)
    #246140
    You have to check the heating element for continuity/resistance first, if it is OK then the PCB is almost certainly at fault.
    With the plug out of course. πŸ˜‰
    nightstalker3188
    Ok… will take a look in the morning…
    I am kinda thinking its the pcb.. as the washes do not seem to make it past the prewash cycle…Saying that I just tried a 40 wash and that did make it through to the end however it did end up with the delicates light flashing – and just for a change when I opened the door I could feel a bit of heat….. So kinda wondering again now what is at fault… the heating element seems to be heating up but then sommet fails at the end…
    #246142
    nightstalker3188
    Looks like it is the control module…
    anychance of how to replace this unit and the cost??
    Oh and the model number….
    regards
    rob
    #246143
    No, how it works is that you give us the model number. πŸ˜‰
    If it is a DWT10 then the part number of the PCB is C00143207. Its inside the door behind the top facia, some very sharp edges so be sure to pull the plug and handle with care.
    An e-mail to spares@ukwhitegoods.co.uk should give all the price info etc.
