Hotpoint Electronic 800 De Luxe 9526
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Electronic 800 De Luxe 9526
  • #20313
    dougsta
    I came on here a while ago to get advice and spares for my FF92 – wonderful success – it’s still going strong – thank you.
    My washing machine was just about to start it’s spin and “wallop” – it’s like someone’s put a Tiger in my machine and he’s not happy about it! Basically, the innards are trying to burst out of the box which makes a horrendous thumping noise and causes the unit to dance around the kitchen!
    Unplugged, disconnected hoses then took the top off suspecting that one of the anchoring springs on the top may have broken but they are both OK.
    Took the panel off on the rear low down to look at the suspension struts/dampers – don’t know the proper name for them. Now how do I tell if these are the things that have failed? One of them looks newer than the other – perhaps due to some water leakage on the “water in” side which has dripped down and caused the ageing of that strut. The plunger bit on that strut is dry.
    The other strut (non-water in side – or right hand side as you face the machine) shows a bit of oil on the plunger bit.
    So……
    Can anybody throw any light on this? I could be way off the mark thinking it’s the suspension struts.
    Does a strut or two need replacing?
    If so – I can see how they fix into the base of the case but how do they fit to the drum?
    Can I get all the spares I need?
    How much do you think it might cost assuming I can do the repair myself?
    And the big one……this is an old machine which although we are happy with it – is it worth fixing it up? Especially as it has a bit of a leak which is causing corrosion on the inside of the case at the bottom. Throwing good money after bad and all that…… 😕
    All advice gratefully received
    Ta
    Doug
    #186610
    Re: Hotpoint Electronic 800 De Luxe 9526
    Have a look at the underside of the machine. You sometimes get cracks in the base panel where the suspension units bolt on. You also can get one of the suspension units break off where the rod meets the drum. You can check this by looking and feeling to see they are secure. These rods are not easy to replace as there is very limited access to the retaining nut and you also need to grip the rod itself to stop it turning. Other items to check are the concrete blocks (see if they are loose) and the drum bearings/spider. Unfortunately, the only satisfactory way to check for a cracked drum spider is to remove the inner drum
    #186611
    Had it drained before it started the spin?
    dougsta
    Penguin45 wrote:Had it drained before it started the spin?
    I think it had just drained the wash water and was doing one of the intermediate quick spins – before it was due to fill up with rinse water.
    #186613
    Before getting too complicated with this, check the filter in the bottom hose. If the water isn’t getting away quickly and easily the drum can bang around all over the place. Power off……
    dougsta
    Good adice – thanks – will check now
    However – it did drain in the end (did complete cycle with the top off and hence not banging on the case)
    Will report back
    Doug
    #186615
    dougsta
    Filter clear – maintenance washes seem to have been doing their job
    Wife has convinced me that a new machine is due.
    Hence this one is up for grabs for parts. Is there a market for this kind of thing? Drum/Programmer/Motor etc are all OK.
    Am loathe to throw it all in the tip too.
    Ta
    Doug
    #186616
    dougsta wrote:Is there a market for this kind of thing?
    ‘fraid not Doug 🙁
    You’ve had the best out of it over the years (probably done in excess of 18 tonnes of washing in its time I expect?) and time to call in the local council to give it a decent send off into the ‘recycled’ after life! 😉
    #186617
    dougsta
    Thanks all
    Will phone the council – £7.50 to take it way.
    In the meantime – if any of the parts can be re-used by people from here will send for the cost of p&p. Just let me know.
    #186618
    dougsta wrote:Will phone the council – £7.50 to take it way.
    Wow that’s cheap, they charge £10 down here! 🙁
    #186619
    dougsta
    I just gave them a call – if you take it to the tip yourself then it’s free.
    They dispose of and re-use as much of the materials as possible. Am struggling to find anyone who will actually take the machine off my hands and re-use the parts.
    Anybody know any more than this?
    Ta
    Doug
    #186620
    dougsta
    Just signed up to freecycle
    Maybe it will do someone some good
    #186621
    dougsta
    I stripped out the wiring loom, motor (with door catch cable & mechanism attached) and the sump part from this machine before I ditched it.
    Meant to do the freecycle thing but never got round to it. Put the parts in a box in the garage. have just cleared out the garage and need the space.
    Does anybody want this stuff? – all fully operational when I took apart. I can’t landfill this stuff – It must be useful to someone, somewhere.
    If I’m in your area I’ll even deliver for free
    Doug
