hotpoint element stats all wma wm wf wt wd models
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint element stats all wma wm wf wt wd models
  • #24890
    gcb
    hello and good afternoon all. Does any no of any way to test these stats or even get a readin on the meter for them
    ……………………………cheers………………..
    #203688
    maltheviking
    Re: hotpoint element stats all wma wm wf wt wd models
    Do you mean the thermistor? 😕
    #203689
    gcb
    yes i mean the thermistor get them confussed sorry
    #203690
    gegsy
    You would need the tech sheet for the specific appliance which will have a table to which the resistence reading you glean will correspond to a temperature, obviously if they match eg 120k on meter and you measure temp as 20C and table gives reference 120k = 22C then you on a winner.
    HTH
    gegsy
    Thanks for PM gcb.
    Just to clarify, you take the readings of the thermister in situ, ie whilst still inserted in heater unit etc; and with the wires from appliance to it disconnected.
    No power is required to appliance either.
    gcb
    cheers gegsy will give it a shot
    #203693
    A thermistor is a temperature-sensing element composed of sintered semiconductor material which exhibits a large change in resistance proportional to a small change in temperature. Thermistors usually have negative temperature coefficients which means the resistance of the thermistor decreases as the temperature increases. However, thermistors are fairly limited in their temperature range, working only over a nominal range of 0°C to 100°C . 😉
    Therefore a mean average resistance readings vary dependent on the size of the thermistor and its location on the appliance. Manufacturers sometimes state their readings in service manuals but as a rough guide: –
    0 °C = 35kOhms
    25°C = 13kOhms
    45°C = 7kOhms
    60°C = 3.5kOhms
    90°C = 1kOhm
    On an typical washing machine testing the thermistor at room temperature you should expect a reading somewhere between 25k and 15k. 😉
    They very often go either open circuit (between the terminals) or short circuit (to earth), and therefore if you get a reading something similar to the above list, chances are the thermistor is fine. 🙂
    #203694
    gcb
    cheers martin for quick response….
    #203695
    maltheviking
    Unless its one of those whirlpool dishwasher ones that test OK but are faulty 😕 :rolls:
    #203696
    gegsy
    I agree, some read ok until you get water ingress, then off they go with random readings 😕
