Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint Engineer’s Quick guide
- This topic has 5 replies, 4 voices, and was last updated 15 years, 3 months ago by
garn.
December 31, 2010 at 8:08 pm #59869
garn
ParticipantLately Iv been out On a few Hotpoint WT WML Models Customers Complaining of Low Quality Spin faults.
Iv failed To select a A full test On These by Selecting options Buttons 2+3 And D program Like It Is On The WMA Models.
Most Of The Time The appliance Is In A Tight Spot In The Kitchen. Or Under Neath The Stairs :rolls: lacking room to Pull the Motor Off.
Its Labor Intense And Its Knocking The Stuffing Out of be After An hour or so.
more Often than not There Nothing wrong With The Appliance The Customer has Selected A Low Spin Program.is There any Where i Can get These diagnostic info From.
Tried Hotpoint Themselves I was Told Hotpoint Don’t Exist Anymore. This is Indersit And we Don’t Give Any Help.garn happy and Prosperous 2011
December 31, 2010 at 8:23 pm #339888Turbo
ParticipantRe: Hotpoint Engineer’s Quick guide
Diagnostic tests will not help on this one.
Just tell the customer not to select the low spin program 🙂Graham
January 4, 2011 at 7:41 pm #339889robstech
ParticipantIs it possible this model is aborting the spin cycle because of a too small load or an out of balance load? Have you tried spinning a test load?
January 4, 2011 at 8:28 pm #339890garn
Participantrobstech wrote:Is it possible this model is aborting the spin cycle because of a too small load or an out of balance load? Have you tried spinning a test load?
The appliance is OK .
Just Wanted The Info To Access The Test Procedure for The recent WT WML version’s
Thanks Anyway garn.
January 4, 2011 at 10:12 pm #339891iadom
ModeratorRe: Hotpoint Engineer’s Quick guide
Unless you have the Emit software or the hardware key then you cannot run through a test procedure, and to be honest the hardware key only tells you what the flashing lights tell you anyway.
January 5, 2011 at 11:22 am #339892garn
iadom wrote:Unless you have the Emit software or the hardware key then you cannot run through a test procedure, and to be honest the hardware key only tells you what the flashing lights tell you anyway.
Thanks jim.
I have The hardware key And The card reader Cost A Load of money 2years ago Never used Never Heard Of Anyone using It :rolls:ta Paul…
