Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint error code. “Daily wash & Eco Flashing on
- This topic has 9 replies, 5 voices, and was last updated 17 years, 11 months ago by
acdodge.
April 19, 2008 at 12:29 pm #36145
acdodge
ParticipantHi,can anyone advise please.Hotpoint dishwasher runs and washes properly some of the time but we have the 2nd(Daily wash) and 4th Light (Eco) flashing at end of cycle. When it doesn’t wash properly the wash cycle is a lot shorter?
Any ideas please
Can we & how do we resent the electronics?
Your assistance is appreciatedApril 19, 2008 at 1:11 pm #249742stripey
ParticipantRe: Hotpoint error code. “Daily wash & Eco Flashing
Do you have the model number?
April 19, 2008 at 1:31 pm #249743acdodge
ParticipantHi Sorry the Model No is BFI620 Cod 37307080100
Hope this helpsApril 19, 2008 at 5:12 pm #249744Penguin45
Heater fault – can be heater, wiring or pcb. Perform resistance test on heater as a starting point, power off first.
April 19, 2008 at 8:59 pm #249745acdodge
Hi Penguin45,
Thanks for your reply. Will borrow a meter tomorrow and test, however water is heating up ok. Although machine works sometimes it always brings this fault code up now. Could this be intermittent pcb fault? Or could the heater be intermittent?
Best wishes
April 20, 2008 at 12:02 am #249746Penguin45
Heaters generally work or don’t – if it’s a bit hit and miss, I’d be suspicious of the relay on the PCB.
February 27, 2009 at 2:41 am #249747simonfinley1975
Already chaged heater what is the pcb?
February 27, 2009 at 2:52 am #249748aqualectric
Printed Circuit Board….or sometimes called the module. Sticking heater relays are a common fault. New PCB is the answer. Not too bad price; try the “Spare Parts” banner at the bottom of each post or the “Shop @” in the left menu for price and availability.
Test thoroughly and be sure you need the PCB…..Power off if investigating. :plug:
March 4, 2009 at 8:54 pm #249749simonfinley1975
Thanks for the info
Was looking at the PCB board, and found one of the wire’s burn out (casing burn but wire ok). What does this mean and is it worth changing the pcb board still
May 30, 2009 at 1:08 pm #249750simonfinley1975
Have replaced PCB but now nothing works no light just a beep when i turn on any thoughts? ready to get up!!!!!!!
