HOTPOINT ERROR CODE = E30
  • #18816
    brett1611
    Hi – What is the error code E30 on a Hotpoint wm72 ????
    PLUS is there a list of ALL fault codes available somewhere
    Thanks Brett 🙄
    #180508
    Re: HOTPOINT ERROR CODE = E30
    At the top of this forum, Known error codes thread.
    http://tinyurl.com/jwzhj
    E30 is no motor action, usually brushes.
    Steven
    If brushes ok, check motor block wires,sometimes there not pushed in properly or damaged pcb.
    Steven
    #180510
    bobokines
    E30 actually means “no tacho pulses”
    If the machine lurches into spin prior to the error code showing. Look for loose tacho magnet, OC tacho coil or bad connection at control module two way connector.
    If there is no motor action at all, then it’s brushes, power module or motor fault.
    Bob
    #180511
    bobokines wrote:E30 actually means “no tacho pulses”
    Which is exactly what happens if the brushes have failed, no motor action, ergo no tacho pulses.
    As a rough estimate, assuming this has a GDA motor I would guess that 75{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of E30’s I have seen are brush failures, followed by loose or broken wiring and armature failure. The incidence of loose magnet, tacho or module failure is not common although it does happen.
    bobokines
    Just to fool you also… some microprofile machines have a fuse on the power module. And some washer dryers have an inline fuse holder buried in the wiring harness.
    Bob
    #180513
    I carry a bag full of them, got them from CPC. 🙂
    #180514
    funkyboogy
    how bigs the bag,
    lol…..
    ally
    #180515
    VillageIdiot2
    Blocked
    Brett, good to see you here! About time! 😉
