Hotpoint EW 31 Oven – Low Temperature
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hotpoint EW 31 Oven – Low Temperature
  • #64958
    pearce_jj
    Hi, I’m hoping you experts can give me some pointers for my mother-in-law’s oven, as above.
    There’s plenty of heat from the element but the thermostat (I presume) seems to be way off, 150*C stabalises at 60*C, 220*C at about 150*C.
    So likely to be a question of changing the thermostat?
    EDIT – to add, fan is running fine. Measurements taken with IR thermometer. As it’s quite old I’d probably pop a new element in too while it’s apart if a new thermostat is the concencious!
    Also it needs a new main oven door handle. Can’t find too much info about this model so any pointers would be very gratefully received!
    Cheers!
    #358638
    Re: Hotpoint EW 31 Oven – Low Temperature
    you dont say a colour but the white handle should be
    part no C00227259
    check the thermostat prob in the oven is still clipped into place. if they come loose and get too close to the element it causes the same symptoms
    pearce_jj
    Thanks very much indeed. Yes it’s white – I’ll check the probe as suggested.
