I have just been to a job where the main oven motor was faulty,which I replaced,after reassembly the cooker tripped when the oven was switched on.
There are a number of strange things about this one as,firstly I discovered the main cooker on off switch wouldn’t click home fully,so this could have been the cause of tripping,and after removal and refitting the cooker now comes on,although the timer seems to be almost impossible to set and even with the auto flashing it starts the main oven motor to run on its own and the thermostat to be switched on and become live although the clock isn’t set!
could this be the trigger board,the clock itself?or has anyone got info on a wiring diagram for the model.
thanks
bruce
