Hotpoint EW81G Cooker Hob Wiring Diagram
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint EW81G Cooker Hob Wiring Diagram
  • #89858
    jontymox
    Good afternoon,
    Wondering if someone can assist with a problem wiring a replacement L/H/F hob regulator?
    Essentially I have purchased an EGO regulator (ELE4123) from Connect Distribution, which has some different terminal assignations.
    Only four connections are used; on the original a single red was connected to Terminal 2, a single red to P1 an insulated black to 4A and a non insulated black to another 4A
    On the replacement unit I have connected a single red to Terminal 2, the other red to P1, and am unsure about the remaining two black connections, as the remaining Terminals are P2, Pilot, and Terminal 4, and do not wish to take chances with their correct positions.
    jonty
    #442780
    Re: Hotpoint EW81G Cooker Hob Wiring Diagram
    http://www.ukwhitegoods.co.uk/downloads … wiring.pdf
    will this help
    jontymox
    Thanks Dave,
    Yes, that helped… the exact EGO regulator wasn’t listed, but was close enough to ascertain that I had a neutral connection incorrect.
    Thanks again,
    jonty
