Hotpoint EW85 – Halogen Ring Fault
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hotpoint EW85 – Halogen Ring Fault
  • #61045
    edh
    We have a problem with one ring – the halogen (front right) It appears to stay on full heat whatever the setting on the dial.
    From a quick browse of your forums it sounds like the regulator
    How easy is this to replace? – Do I need to take off the ceramic hob to get access? (Sides come off to gain access to the top screws I think.)
    Is there anything else it might be? Is it worth testing the regulator or just ordering a new one?
    Ed
    #344672
    Re: Hotpoint EW85 – Halogen Ring Fault
    It does sound like a faulty regulator and as the cost of one is roughly a tenth of the cost of the ring itself it would be the first thing to try.
    Access is not easy, hob has to be released, all knobs pulled off etc.
    Be sure to isolate from the mains if you are gonig to attempt this.
    Part number is a C00199654.
    #344673
    edh
    I think I can get this sort of job done – have seen this cooker taken apart before.
    I will turn off the mains at the consumer unit – don’t want to take any chances with electricity.
