Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Hotpoint EW91 Halogen Double Oven – repairs advice
- This topic has 15 replies, 3 voices, and was last updated 8 years, 1 month ago by
cfam.
February 12, 2018 at 10:16 pm #93310
cfam
ParticipantLooking for spare parts for Hotpoint EW91. Two faults so far:
1. The upper left and lower left electric rings no longer respond to the temperature control dials. I assume that a temperature regulator has failed. Can these be replaced?
2. The solar grill element also does not respond to the temperature control. Can this be replaced also?
Thanks in advance.
CFAM.
February 12, 2018 at 10:36 pm #453886electrofix
ModeratorRe: Hotpoint EW91 Halogen Double Oven – repairs advice
basically 2 controls
yes they can be replaced
suggest you message the site shop with all model and serial and ask
https://shop.ukwhitegoods.co.uk/
I put the model in but a number of option come up so it needs to be looked up on the manufacturers service info
February 13, 2018 at 7:02 pm #453887cfam
ParticipantRe: Hotpoint EW91 Halogen Double Oven – repairs advice
Dave,
Thank you for your advice. Just received the serial number so I’ll head over to the shop.
CFAM
February 13, 2018 at 10:47 pm #453888iadom
All parts the same across all three model variants.
To identify it would be better to say which controls you think are faulty rather than upper left and lower left rings.
Give us the controls by number from left to right that you suspect are at fault.
Does the solar grill element come on at all ?
Using the attached picture may be of help in identifying the three regulators you need.
Not the easiest of jobs, both sides have to come off and the complete hob has to be loosened and moved out of the way as well as all the knobs etc.
February 18, 2018 at 3:15 pm #453889cfam
Hello Dave, Iadom,
Thank you for the picture, this was supplied separately by the shop staff. The controls I believe are at fault are positioned 1 and 2 from the left. With this information, the shop staff have supplied compatible parts, which I have received and I am now attempting to install. However, the pins seem to be different.
part supplied for control 1 https://shop.ukwhitegoods.co.uk/ele4123 … -regulator
For control 1 (image attached), assuming this is the right part, I have labelled with arrows where I think the pin positions in the new component (left) relate to the old component (right). The connection for the red wiring appears straight-forward but the black wires it is not obvious. On the old component the position is labelled 4A but there is no equivalent position on the new component.
part supplied for control 2 (dual regulator) https://shop.ukwhitegoods.co.uk/cs146-c … -regulator.
For control 2 (image attached) again I have labelled with arrows where I think the pin positions transfer across from the old (left) and the new (right) components.
So my questions are:
(a) have I got the right parts
(b) have transferred the pins across correctly.Additional information:
The serial number for the cooker is 88 1 000 43.I’ve parked the issue of the grill for the moment.
Any thoughts?
CFAM.
February 18, 2018 at 4:51 pm #453890electrofix
the contact numbers need to be seen to be certain and I can make them out from these photos clearly
February 18, 2018 at 5:49 pm #453891cfam
Hello Dave,
Thank you for your reply. I have uploaded the photos again highlighting the contact numbers. For clarity I’ve removed my arrow labels.
CFAM
February 18, 2018 at 5:57 pm #453892cfam
In case these images are not clear then higher resolution images can be downloaded from my dropbox using the links below:
February 18, 2018 at 7:36 pm #453893electrofix
no probs as far as I can see just match numbers
top one number for number
bottom one match numbers apart from both leads from 4A go on 4
February 19, 2018 at 1:49 am #453894cfam
Hello Dave,
Thank you for your guidance. I have installed control 2, as this was straight-forward. But control 1 requires crimping the two black leads together and I don’t have the right tool with me so I’ve had to leave this for the time being. A bit of pain putting the whole cooker back together though. The new control 2 unit appears to be working fine. Once the cooker was back together I looked at the problem with the grill.
Using the diagram provided by Iadom, the control for the grill is the first one from the right (I’ll call this control R1). I asked my Mother to show me what she does to switch on the grill. This involved switching on the main oven for a couple of minutes then switching it off then switching on the grill. I noted that the solar grill elements had a slow oscillating glow, i.e., they would heat-up then cool down. This was the same for both the dual and single side settings. This suggests to me that the regulator needs replacing. I have captured the problem on camera but will have to post a link sometime tomorrow.
Any thoughts?
CFAM.
February 19, 2018 at 9:37 am #453895electrofix
you should not need to operate oven first to use the grill
turn the grill control to its highest setting and see what happens
these controls work on time so for example half heat will do the following
lets say a time cycle is 10 sec so the unit turn the element on for 5 secs and off for 5. full power is permanently on and lower temp just alter the ratio. As the control wears it may go out of calibration and not turn on enough. One of the ways you can tell is try turning the grill control slowly on and listen carefully for the click as the contact operates. it should click before it reaches the first number otherwise it wont turn on early enough
https://www.altecautomotive.co.uk/635mm … 3850-p.asp
March 27, 2018 at 7:36 pm #453896cfam
Hello Dave,
So Easter is next week and part 2 of the fix looms.
Thank you for the weblink. I was puzzled at first (penny in the air) as to why I was browsing a site for boats but then realised the solution, I don’t need a crimper just a piggy-back (penny dropped).
Now for the grill – using the parts diagram shown earlier the control is the first from the right. When switched to its highest setting the grill elements instead of staying switched on cycle on and off, which is what I would expect if the setting was at its lowest. From this I assume that the control unit needs to be replaced – which part is need for this?
CFAM
weblink to a short movie that I took during my last visit.
https://www.dropbox.com/s/dncozy65ffggs … 2.mp4?dl=0 (takes a minute or so to load before viewing).March 27, 2018 at 9:21 pm #453897electrofix
grill control does look most likely for that fault
https://shop.ukwhitegoods.co.uk/c002295 … -regulator
March 29, 2018 at 10:38 am #453898cfam
Hello Dave,
Forgive my tardy reply – spent the past couple of days tidying the house – I have my parents coming to stay for Easter.
I have ordered the part and hopefully it should arrive before I need to travel back North.
The piggy-back clips arrived this morning.
Thanks for you advice.
CFAM
May 28, 2025 at 1:08 pm #453899cfam
ParticipantAfter some searching, I’ve found my previous posts on this subject. My Mother’s trusty cooker needs some tlc …. a new temperature regulator – details are the same as in message #5; however, the web links no longer work (presumably because the catalogue has been updated). Using the diagram in message #4, the part number is 121. (In the diagram, the part number 109 is for the four controls – working left to right: lower left, upper left (dual), upper right, lower right (halogen). The upper right is the one exhibiting the fault. An updated web link would be helpful. I have tried using the search button on the ukwhitegoods shop page but it just crashes returning the error message “An error has happened during application run. See exception log for details.”
