Hello all
I am reposting this in the hope that someone can help. This w/m Hotpoint BWD129 fails to complete a cycle. Out of the last 6 washes it has completed 2 and failed on 4. Stops with water in and lights 1 & 3 flash.
Looking at Indesit codes this indecates F10 a pressure switch fault. Is this correct ❓
Are these switches prone to failure ❓
The hoses / pump are not blocked although the pump could have an intermitent fault I suppose.
The machine is 3 yrs old with one young lady owner.
Its built in on the 3rd floor of a block of flats. The young lady tennant is only in at times when i’ve normally finnished work so its a pain. If it had been on the ground floor I would have taken it back to workshop and loaned her a machine while fixing this one.
Help if you can thanks.
