Re: HOTPOINT F/F MODEL FFO6W
There’s three thermostats on the evaporator plus the two heaters so it’s a bit “overkill” to change all of them.
One of the thermostats is the fan initiation one which should be open circuit in warm conditions, the other two will be nc, the two heaters can also be checked for continuity quite easily. It could also be the defrost timer.
Part numbers as follows for all the parts:
Timer 2600054
Defrost heater 2600092
Drip tray heater 2600061
Defrost cut-out and thermal fuse (4 leads ?) 2600058
Fan thermostat (2 leads) 2600059
Thermal fuse (blue, 2 leads) 2600074
