Hotpoint F/L/A (WMF560) – F06 error
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint F/L/A (WMF560) – F06 error
  • #68904
    neon_3SP_glow
    Hotpoint automatic washing machhine
    Model – WMF560
    Customer complains of F06 error code towards the end of the programme. Fault is intermitten.
    I could not find any info on F06 other thatn what EMW had sent me saying F06 in N/A!!!
    Seen this before anyone? Many thanks.
    #373132
    Re: Hotpoint F/L/A (WMF560) – F06 error
    In the manual it also states F06 as N/A in the quick reference list but in the expanded list it has this for F06.
    Door lock fails to close / open, doorlock PTC triac open/ closed, mains frequency signal fault, mains power signal fault.
    – Check for water leaks that may affect connectors J004 or J11
    (three-phase) causing the relative contacts to short;
    – Check Door lock terminal board (any problems due to
    aggression caused by manufacturing chemical residues that may
    cause short circuits);
    – Check J004 / door lock wiring;
    – Check door lock;
    – Renew PCB.
    #373133
    neon_3SP_glow
    Many thanks for the info here – I have added it to my error code list 🙂
    As it turns out the customer only ever had the fault once and it resolved itself without me even visiting.
