Hotpoint Fault after F05 wmud942x uk
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Fault after F05 wmud942x uk
  • #92651
    simon26r
    wmud942x uk
    Ok, Customer moved house and everything was good, machine filled and done a wash until the drain and he got f05 as he did not remove the stub under the sink.
    Now if you put on a wash it drains then goes into a wash but no water.
    I have put a some water in the drum and put on to drain to reset the pressure switch. Have also checked all cables ect. I would have thought if the pressure switch had a fault it would continue to drain with the f05 error or am i wrong
    Put on any wash program door locks> drain pump> drum starts to wash > 1 second drain pump> continues to wash with no water.
    Any ideas
    #451804
    kaibart
    Re: Hotpoint Fault after F05 wmud942x uk
    Pcb and linear pressure switch done loads
    #451805
    simon26r
    Thank you
