Hotpoint FDAL28P dishwasher fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint FDAL28P dishwasher fault
  • #93134
    lyndy
    We’ve looked at a Hotpoint dishwasher FDAL28P (SN 212053456 / 36769880100) with a fault and wondered if anyone can shed any light on the cause? Details as follows:
    Machine will start ok and wash for 5 mins on the daily wash cycle. After five minutes the following lights flash and the machine drains and stops.
    Start/pause – constant rapid flash
    Wash – constant rapid flash
    End – constant rapid flash
    We’ve checked to see if this is a leak-into-base job but there is no water in the base tray and we can’t see a leak anywhere.
    Once the machine faults, it can be reset and will start again as above before faulting again.
    Any suggestions?
    Thanks in advance.
    #453314
    Re: Hotpoint FDAL28P dishwasher fault
    99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain it uses the same codes as the FDL range. Sadly looks like 1+3+4. 🙁
    lyndy
    Thank you – very useful. We couldn’t find the fault codes for it anywhere. But yes, looks like a bad result!
