Hotpoint FDAL28P (Ind: 36769880100)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint FDAL28P (Ind: 36769880100)
Viewing 1 post (of 1 total)
  • #98467
    Hollytree_Technical
    Hi All
    I strongly suspect a dodgy main module on this one but wondered if any of you had seen this issue first.
    This machine aborts the program with an “F05 – Pressure Switch Non Compliant” error, I have already checked the pressure switch and hose for leaks and switch contacts for continuity as well as blown through the air trap and test the wiring, if I put the machine through a test cycle it runs fine and will then work happily for a couple of months/weeks before playing up again.
    Jem
