Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint FDEU8640PUK
- This topic has 10 replies, 2 voices, and was last updated 1 year, 11 months ago by
WhiteVanMan1.
May 3, 2024 at 2:25 pm #102734
WhiteVanMan1
ParticipantThe machine starts, fills and agitates ok. After about eight minutes, the super wash, slow spin, time saver, and eco wash led’s start flashing and it goes into pump out mode. I’ve checked all heaters, all ok. I’m suspecting a control module heater circuit fault. Any ideas please? Also, I I’ve looked at modules just in case, but it seems they only come unprogrammed. Any assistance greatly appreciated thank you. Steve.
May 3, 2024 at 8:55 pm #490267electrofix
Moderatorfault code on these will be the vertical lights on the right
from the bottom which ones are lit and not lit
normally the lights are binary so first light is worth 1 when lit , the next 2 followed by 4, 8 and 16 you add these up to get code
May 4, 2024 at 8:53 am #490268WhiteVanMan1
ParticipantThank you for your reply Electrofix. Only light illuminated on the vertical bank is the door locked light. The four horizontal lights are flashing.
May 4, 2024 at 10:09 am #490269electrofix
Moderatorok that look like poss fault 1
fault 1 is motor triac problem but earth leakage on the motor has been known to cause this on some machines
could be as simple as carbon dust also chech for small leaks onto motor
May 4, 2024 at 12:08 pm #490270WhiteVanMan1
ParticipantCheers Dave. Motor is brushless and works fine. It seems to get to heat pause, then go into fault mode. At the moment she’s waiting until it goes into fault mode, then restarting on the rinse and spin programme to finish the wash, which it does without a problem. Steve.
May 4, 2024 at 1:25 pm #490271electrofix
ModeratorF01 is one of those aweful codes with many problems
this is not your machine but will give you ideas
have not got manual for your model
May 5, 2024 at 6:18 am #490272WhiteVanMan1
ParticipantThank you for that Dave, it’s very much appreciated. I think in light of all the facts, I’m certain in my mind that the fault lies in the PCB. My problem now is that the only PCB’s I can find are all unconfigured. Looks like a I recommend a call to Hotpoint . Thank you for your help. Steve.
May 5, 2024 at 8:29 am #490273electrofix
Moderatorjust for your ref
Aswo can supply configured boards
May 5, 2024 at 3:03 pm #490274WhiteVanMan1
ParticipantCheers Dave. Not used them before but will give them a try. Thank you so much for your help.
Steve.May 5, 2024 at 3:25 pm #490275electrofix
ModeratorAswo are brilliant
stock is excellent and even has triacs relays and lots of electronic components , memory pens etclots of helpful tech really really good on vestel machines
May 6, 2024 at 9:41 am #490276WhiteVanMan1
ParticipantCheers Dave. Much appreciated
