Hotpoint FDF 780 dishwasher (dish waster)!
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint FDF 780 dishwasher (dish waster)!
  • #70914
    Muv
    Hi all
    Got this machine that customer says stopped after cycle and showed error code A8 (faulty heater)
    Have checked heater and that tests ok
    Have run machine on full cycle, it drain,fills, then just stops dead and continues counting down
    Have taken out wash motor and tested coil. And thermal cutout
    Coil gives a reading of 30k ohms
    And cutout tests ok
    I also have full voltage at terminals
    But still machine won’t progress any further with the cycle..
    Any ideas appreciated..
    Criscold
    Re: Hotpoint FDF 780 dishwasher (dish waster)!
    There is a test procedure for this, PM your email and I send you some info
    Colin
    #379370
    Hollytree_Technical
    30K Ohms?!…. or should that be 30 Ohms as it sounds rather high if it is 30,000 Ohms and would say to me that that is the fault right there and if that is the insulation reading then it is too low – either way that doesn’t sound right.
    Jem
    #379371
    Muv
    Yes that seems to be the problem, it’s coil is getting the correct voltage.. But it’s struggling to turn the impeller, although it is fairly free to turn by hand?
    Muv
    Thanks to you both for your help
