Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint FDF780
- This topic has 13 replies, 5 voices, and was last updated 15 years, 6 months ago by
robbra.
October 5, 2010 at 3:50 pm #57735
robbra
ParticipantHi,
Customer rang and going tomorrow.
Fault indicated is A7……done a search and found nothing so can anyone enlighten me?
RobOctober 5, 2010 at 4:00 pm #332115Martin
ParticipantRe: Hotpoint FDF780
Water inlet problem.:wink:
October 5, 2010 at 4:03 pm #332116petalpop
open/short circuit wash motor triac
that is off the hotpoint service .co.uk web-siteOctober 5, 2010 at 4:33 pm #332117Martin
petalpop wrote:that is off the hotpoint service .co.uk web-site
Are you referring to THIS Hotpoint web site?
October 5, 2010 at 4:42 pm #332118robbra
Thanks,
I couldn’t get that model to appear. Don’t know whether to go out to it or just tell him. 😉
RobOctober 5, 2010 at 5:11 pm #332119Bernie
Martin I think petalpop was refering to Hotpoint’s site:-
October 5, 2010 at 5:13 pm #332120iadom
ModeratorRe: Hotpoint FDF780
..A7 = Module has detected no Turbine rotation. check turbine and
wiring.Or as Martin says, a fill problem. 😉
October 5, 2010 at 5:15 pm #332121robbra
Is the turbine like the “impeller jug” on the Bosch?
Just got the email Jim
ThanksOctober 5, 2010 at 5:16 pm #332122iadom
Yep, check your inbox. 😉
October 5, 2010 at 5:21 pm #332123robbra
Just one more question………………………..
Where do you get all this info? I’m intrigued
October 5, 2010 at 5:45 pm #332124iadom
I plead the fifth amendment. 😉
October 6, 2010 at 8:06 am #332125Martin
Bernie wrote:Martin I think petalpop was refering to Hotpoint’s site:-
http://www.hotpointservice.co.uk/hs/pag … RROR_CODES
Couldn’t help noticing that the vast majority of those error codes listed throughout that page all relate to exactly the same fault : “Book a repair!”
October 6, 2010 at 10:21 am #332126Martin
robbra wrote:Where do you get all this info? I’m intrigued
I’m pretty sure that in the fullness of time Jim will post the full list of those error codes in the Known Error Codes thread if I’m any judge? 🙂 😉
October 10, 2010 at 9:40 am #332127robbra
Thanks to Jim I went to this armed with the info. It is the same as the impeller jug system but the mini pcb is fixed into the matrix so can’t be repaired but the complete unit isn’t too expensive at around £16.
Amazing a how a bit of info helps with the job.
Cheers
8) -
