Hotpoint fdfex11011k f06 fault
when starting the wash cycle the machine drains and then after about a minute or two shows the red tap symbol and shortly after displays f06 and bleeps.
i have established that there is no voltage being send to the inlet solenoid.
(i can activate the solenoid by applying a 240v supply directly and the machine will fill)
i have also checked the operation of the level/pressure switch and that operates correctly.
if i manually fill with water after the initial on start draining the machine will commence the pre rinse and drain then the f06 will return.
can anyone help?
