Hotpoint FDL 570
  • #85506
    fluffwump
    Hi I have searced and can’t find an answer to this one, I have a hotpoint FDL 570, the dishwasher is making a rumbling sound &b the salt & rinse lights are flashing along with the 6hr and 9hr lights, any ideas?
    Many Thanks
    #428753
    Re: Hotpoint FDL 570
    Supposed to be a fill time out error, water fill turbine most likely cause.
    #428754
    fluffwump
    Is it an easy fix, or is it dead?
    #428755
    That all depends on ones technical abilities. 😉 Changing the turbine is not that difficult and not a major expense but other things can cause that error code. poor water pressure, inlet valve, connections, timer, or the water
    turbine.
    It shouldn’t really cause a rumbling noise either but the main circulation pump on these Indesit dishwashers is also a known weak point.
