Hotpoint FDL570
  • #79561
    baronoftheeast
    I apologise if this has been covered I think I’ve scoured the site enough and I cant find it.
    I have a hotpoint FDL 570 that runs as usual and then stops and the Play/pause and drying/3h lights flash.
    According to the manual this means ‘Water loading solenoid valve fault’.
    a, Is this correct
    b, What would be the next step in fault finding this?
    Many moons ago I used to repair CRT televisions so I’m moderately technically minded but do not know what I’m looking for.
    Any help would be gratefully received, thank you in advance. 😀
    #409704
    Re: Hotpoint FDL570
    If the error code is correct…
    The water valve is not opening but it wouldn’t fill if that were the case usually.
    The control module isn’t detecting the water valve.
    The control module isn’t receiving the signal from the pressure sensor to tell it that water has reached level.
    It’s a very simple logic generally speaking and from that you should be able to work out what the issue is unless there’s something that jumps out on the range or model.
    Re: Hotpoint FDL570
    Could be the air break turbine. Several different models of this machine, full model number, serial number and commercial code needed to ID correct parts.
    #409706
    baronoftheeast
    Re: Hotpoint FDL570
    Thanks for the responses,
    I haven’t help anyone by incorrectly stating the error code, It should have read the :play/pause & drying/6hr light flash.
    Numbers on the back are:
    FDL 570 6.R
    3663944090003
    0928-00721 6539
    I actually replaced the air break turbine ( supplied very promptly by yourselves) last week to no avail.
    Any additional help would be very much appreciated, I’m about to start the ‘cheapest part first” fault finding method!
    #409707
    Re: Hotpoint FDL570
    Equates to lights 2+4 for error codes.
    Heating element, connections, module, relay, pressure
    switch.
    Most likely culprits heater or main pcb. The heater needs testing for resistance/continuity, if that is OK then it’s odds on the module. 🙁
    #409708
    baronoftheeast
    Re: Hotpoint FDL570
    Hello,
    Finally got round to getting in there and having a look, the heater is reading 7 ohms across
    the terminals, with it disconnected. It also has a nasty burn mark on the metal casing so perhaps its shorting?
    7 ohms on a 1650w heater seems a little low to me? What would you suggest?
    Many, Many thanks
    #409709
    Re: Hotpoint FDL570
    Heater resistance should be 29.9?
    #409710
    baronoftheeast
    Re: Hotpoint FDL570
    Aha, I’ll be placing an order post haste. Cheers
    #409711
    baronoftheeast
    Re: Hotpoint FDL570
    Ok, part arrived today – thank you – seemed straight forward enough to fit.
    I am now getting the 3hr & 6hr lights flashing, accompanied by a whirring noise without the usual sound of water flowing. Any advice?
    The dishwasher ejected water through the waste pipe so that seems ok
    The water line in is turned back on!
    Many thanks
    #409712
    Re: Hotpoint FDL570
    The main circulation pump is as unreliable as the heater and the electronics, sounds like that is goosed. It is an Indesit when all said and done. :rolls:
    Lights 1 + 2…Time out draining Pump connections, blockage, module, circulation pump.
