Re: Hotpoint FDL570 filling not in use
if it overfills, even when off, it will “come on” and pump out the water assuming is still plugged in. Was there c rap in the old valve’s filter when you took it out? might just be repeated valve failure due to rubbish coming down the pipes. Faulty water softener (in the house not the one in the dishwasher) are favourites for this. If not then stick a voltmeter on the valve incase the electronic is feeding it with a few volts.
