Hotpoint FDL570 Flashing lights
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint FDL570 Flashing lights
Viewing 15 posts - 1 through 15 (of 15 total)
  • #86863
    Sebypaul
    I have a Hotpoint FDL570 and the washing kicks start normally, but the Salt, RinseAid and Wash light start blinking and the whole process stops. I can see some leakage of water under the machine when I pulled it outside the cabinet. Any idea about the fault? Thank you.
    #433215
    Re: Hotpoint FDL570 Flashing lights
    That error code is exactly that that, you have a leak in the base which needs investigating and fixing.
    #433216
    Sebypaul
    Thanks. I can see the rubber gasket is not seated properly. I took it out and installed it back, but no joy. Is that something available to buy? If so, how much?
    #433217
    Which rubber gasket??
    #433218
    Sebypaul
    I meant the bottom rubber beeding seal of the door.
    #433219
    Ah, I have a horrible suspicion that comes as part of an inner door panel, part not listed as a separate item, not usually a cause of leaks into the base though.
    #433220
    Sebypaul
    I opened the the bottom plastic cover of the dishwasher today and found that the leakage is from the bottom side of the machine. Looks like the motor is leaking. I unplugged the motor. Do you know how much this unit can cost?
    #433221
    Part number C00256525, around £93.00
    #433222
    Sebypaul
    Mate, the leakage is from the Heating Element. There is a tiny hole and the water leaks through that hole. Not sure whether the leakage has damaged the coil as well. Do you think it’s worth closing the hole and check again. Is the Heating element expensive to buy?
    #433223
    Heater is part of main pump assembly, cost around £50. part number C00256527.
    #433224
    Sebypaul
    Very helpful. Thank you.
    #433225
    Sebypaul
    Merry Christmas.
    Managed to replace the heating element. It stopped leaking. Tried the wash cycle with Daily Wash and looked OK for an hour, I could listen to the washing sound from inside and then stopped with error code flashing Salt+Rinse Aid + Drying. Switched the machine off and on. Change it to Speed Mode, but same effect. Washed for a while and stopped with same error code. It sounds like the machine is still trying to do something, but no joy. Already spent £50!!!
    #433226
    Valve or turbine faulty. Inlet valve, connections, valve letting water pass through
    when off.
    #433227
    Sebypaul
    Thank you. Any help how to troubleshoot?
    #433228
    Not really, strong possibility you have disturbs something though.
