Hotpoint FDL570. 37544470000. S/No:- 805302540.
Fault reported:- stops in cycle as if it has been paused; start button light pulses. Will sometimes restart if buttons are pressed.
Well as usual with this type of call it works fine for me on visit. 👿 Test heater, motor seems relatively quiet (I know these fail regularly) fills and empties fine. Meggers out OK – drain pump is working but noisy. Customer says machine is empty when it stops but the crocs are not dry.
So all the components work, I assume it is a module problem. Unless anyone can shed some light on this……
Thanks,
Steve.
