Hotpoint FDL570GR problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint FDL570GR problem
  • #78281
    LloydIe
    hi, my dishwasher has given up the ghost. The salt and rinse aid lights are constant red and the wash/3hr light is constant amber. There are no flashing lights. When I switch it on it fills with water which doesn’t heat up. After a few minutes it starts making a rhythmic humming noise but does nothing. No water is pumped around and the arms are still. When I switch it off it drains as usual.
    Having read other threads I guessed the heater and main pump were at fault. I removed these and checked with the meter and get 50-60 ohms from both.
    Any advice would be most grateful. Thanks.
    #405079
    Re: Hotpoint FDL570GR problem
    Sounds like the main circulation motor has failed, very common fault on Indesit dishwashers. 🙁
    #405080
    LloydIe
    OK, thanks very much for such a prompt response iadom, much appreciated.
