Hotpoint FDL570P.R cannot locate error code.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint FDL570P.R cannot locate error code.
  • #87453
    Trojan Hussar
    I’ve got a Hotpoint Aquarius FDL570P.R and it takes on water pauses for a second flashes the wash/drying/end lights and then drains continually (long after the machine is empty).
    I cannot locate this particular combination of error lights anywhere and the FDL series codes on this site have a disclaimer at the bottom saying they are not relevant for this model.
    Can anyone shed any light on this please?
    Jason.
    #434891
    Re: Hotpoint FDL570P.R cannot locate error code.
    Error code is lights 1+2+3 which indicates a faulty water turbine.
    part number C00256546
    #434892
    the part you may need is HERE
    #434893
    Trojan Hussar
    Thanks for the info, I’ve removed the turbine unit, it’s all nice and clean and the turbine spins freely so I reconnected it. I set the dishwasher to speed wash and it has taken on water and started the first cycle so fingers crossed.
    Thanks,
    Jason.
    #434894
    Trojan Hussar
    It did a couple of washes, so I put the side panels back on and then of course it promptly stopped working again. It now fills with water panics, flashes the lights and continuously empties.
    #434895
    Change the part I indicated, a known problem area.
    #434896
    Trojan Hussar
    Having just coughed up £30 for a replacement water turbine, it arrived today and I’ve just fitted it. Unfortunately it’s made no difference whatsoever.
    When you start a cycle it does a quick drain, pauses and then starts taking on water for a few seconds before flashing all the lights and draining itself.
    #434897
    All the lights or just the three vertical lights?
    Error codes on all appliances are only a guide and we can only follow the details from the manufacturer. Sadly the electronics in this Indesit made appliance are some of the least reliable on the market so anything is possible.
    Can you trace the wiring from the turbine back to the module and check it for continuity?
    #434898
    Trojan Hussar
    Salt/Rinse Aid and the Wash/Drying/End all flash. I was a bit concerned that the drain pump runs continuously even after the machine is empty, which I would assume isn’t that great for an impeller.
    #434899
    Error code is still “supposed” to be a turbine fault. Drain pump will often run continuously in error mode. Especially it thinks it is overfilling. No mention of it in the manual but I’m guessing a pressure switch problem could lead to similar errors.???
