hi,heater open circuit on this one,replaced that but now it only pumps continously,door open or not,guessing it needs resetting or the pcb has been damaged,no visable blow marks tho,anyhelp would be great thanks
sounds like you had water in the base on the first fault i would check for a leak if you dont find a problem remove front panel check wiring harness behind the metal rod runing across wires break in this area
ok cheers,but theres no sign of water in base,iv had this running with side panel off,i think the heater may have damaged the pcb as it is doing alot of strange things,think ill have to scrap it
