Hotpoint FDW 20
  • #47085
    triphop27
    Hi All
    Need a bit of help with machine I have been to see this morning.
    Customer reported smoke coming from back yesterday, this morning Everything meggered fine, no evidence of damage underneath. I ran machine up, drained ok filled ok, when fill was finished there was an electrical “popping” sound which I assume came from the heater, but the machine ran fine for me and the heater was working.
    Have told customer not to use the machine until I can say definatley where the smoke came from.
    All help greatly apprieciated
    John
    #292265
    dpr1974
    Re: Hotpoint FDW 20
    I had the same thing a few years back. it turned out to be the motor, the comm had two bad segments which was causing a crackling pop and sometimes smoke. Don’t know if that helps you at all.
    David
    #292266
    Re: Hotpoint FDW 20
    Mains filter can also cause this problem.
    #292267
    timdowning
    Re: Hotpoint FDW 20
    Did you unplug heater? The connector can melt.
    #292268
    triphop27
    Re: Hotpoint FDW 20
    Thanks for replys, yep unplugged heater and connector was fine.
    Think I will change suppressor and if that doesnt fix it then will look at the motor.
    Will let you know
    John
