hotpoint fdw 65
  • #36772
    mowerman80
    Hi all getting a heating circuit fault code 4&6 on this dishwasher but the heating circuit seems fine it is heating ok. every time i put it through a program its fine and its ok for the customer for the first 2 times then the code comes up again. Does it look like its the board?.
    #252293
    allround
    Re: hotpoint fdw 65
    I know you say its heating fine , but remove heater and look inside , if it is scaled up that is the problem , the elements overheat and the cutout trips , once cooled down they work again . I have had sucess just running a descaler through machine but prefer to change heater and tell customer to do regular descales , Hope this helps
    #252294
    mowerman80
    Re: hotpoint fdw 65
    Ok thanks that sounds like a plan will give it a go and see what happens.
