iadom wrote:If it was filling the base you would get lights flashing an error message. Do you mean filling the inner tub when not in use?
Not sure what you mean by ‘removed inlet solenoid valve’, as this is one of the likeliest causes of the fault did you replace it?
I don’t get any flashing lights error message on the front. The bit that filling up with water is where the plates bowls ect go in from the base pump area i took the intet solenoid out and left it i a bucket over night and did not leak at all if that helps also put the drain out incase it was back fiilling and wasn’t any no replacment parts yet looking to find the right part to replace first
