Hotpoint FDW20P
  • #57783
    happycack
    Morning,
    Friend has the above dishwasher (I don’t do them) says its running through all programmes but dosn’t heat. I checked the inline heater with stat and that’s fine. Presume the stat in the heater is just an overload stat and not running temperature. Can’t see any obvious temp control. Where next?
    Ta.
    #332288
    Re: Hotpoint FDW20P
    If you are certain the heater is Ok then its almost certainly a PCB failure, both heater and PCB are very common faults on these ‘Indesit’ dishwashers.
    Two different PCB’s both around £60 ex vat, list price.
    Full serial number needed to identify correct part.
    #332289
    happycack
    Re: Hotpoint FDW20P
    Thank you. I’ll see what he wants to do. Probably skip it.
    P.
    #332290
    happycack
    Re: Hotpoint FDW20P
    Well he does want it done.
    S/n 71102-2909 37331821000
    Is that enough info for correct pcb?
    #332291
    Re: Hotpoint FDW20P
    C00144314. 🙂
    #332292
    happycack
    Re: Hotpoint FDW20P
    not c00109875 ? Only one I can find on this site and the search engine dosn’t recognise C00144314.
    #332293
    Re: Hotpoint FDW20P
    happycack wrote:and the search engine dosn’t recognise C00144314
    Dunno what “search engine” you’re on about but C00144314 is the correct number for the board you need. 😕
