Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint fdw20p
- This topic has 2 replies, 2 voices, and was last updated 11 years, 11 months ago by
sce.
April 30, 2014 at 8:30 pm #80494
sce
ParticipantHi hope you can help. I`ve read everyone elses contributions on these contraptions and I am a little stuck / need a bit of reassurance. Problem is d/w flashes up 2 and 4 = poss heater, p/swt connections etc.. as per list. This machine does not do this everytime, perhaps once in every 3 washes. I`ve mega`d the heater= ok, checked the wiring=ok, visually checked the pcb for dodgy solderings on the relay = no problem seen. Even so I think it is the pcboard but want to know what part c00142435 high pressure m/swt thing does embedded in a hose; what does this part do , any ideas? The machine sounds good on wash and everything works just fine but as I said 1 in 3 times the poxy machine does fault code 2 and 4 and I`ve been told that it happens mostly on the wash rather than on the last hot rinse but not always….weird……..or is it?
April 30, 2014 at 9:44 pm #413101iadom
ModeratorRe: Hotpoint fdw20p
Indesit and weird go hand in glove. :rolls:
PM me an e mail address and I will send you the manual. 😉
May 3, 2014 at 6:50 am #413102sce
ParticipantRe: Hotpoint fdw20p
my thanks to Iadom for the manual.
Interesting update and a bit of a wild goose chase too: as you may have read the first post above this was a difficult one to pin point because there was nothing wrong with the element e.g mega ok etc….I changed the pcb yesterday in the hope it was that, it wasn`t, Bugger! I changed this part tested it for 2 washes and worked ok then the trip went off which it had never done before, yes you guessed it was the element. What has /been happening was the continuity of element coil was going open cicuit for 9 secs- a hot spot which a mega will not spot, which of course you cannot see- which was enough for the pcb to sense the element breaking down but sometimes it wouldn`t and the machine would work without a problem to the end; about 1 in 3 times. Now it has finally and permamently has gone o/cir; just needs a new element and the machine should now work; sorting it out next week. Shame the poxy thing didn`t pack up `normally` before buying a new pcb which cannot be returned and so a warning that despite testing to the contrary the 2+4 light fault code is spot on there was just no proof at the time of testing that the element was a duffy. -
