Got a problem with this one, Delicate + Fast lights coming on towards the end of the wash and the book shows it a Heater circuit Fault. Trouble is the heater is working, In fact If anything its overheating as the water temp on the 40c wash seemed a bit high to me. Have changed the PCB and now its doing the 40c wash OK but faulting on the hotter washes.
Running out of ideas now.
Didn’t try that as the house has a RCD, But will call again to check. I was thinking this morning that I should have checked for earth leakage as the heaters are prone to failure.
Called again today for one last look before I called it a day, But still none the wiser. Other than that the pcb I fitted had the same fault as the original ie overheating completely stumped.
