hotpoint fdw60g
  • #19433
    robbo1973
    hi all this machine had a strange fault where the filter housing has a large plastic locking type nut holding it in place, which had come loose cust does not know how ,refit and test and the wash pump fan is jammed 👿 stripped off but a sealed unit can you get these seperate or is it a full motor and also what would cause the large nut to come loose?????.thanx
    #183072
    Re: hotpoint fdw60g
    Motor & pump complete I’m afraid, part No: C00080512, £78 + vat. 😥
    Not sure about filter, appears to be the same as most recent Indesit clones. 😕
    Can you post a pic of this large nut?
    EDIT, There does appear to be a different part above the normal filter fixing on these, comes as a two part kit ?????
    #183073
    Dave_Conway
    Re: hotpoint fdw60g
    The pump unit only is C00054979 at £25.27 list, it’s called a “pump cover” for some reason 😕
    The “big nut” is part number C00075111 (part of the lower spray arm support) I think 🙂
    #183074
    Re: hotpoint fdw60g
    Dave_Conway wrote:The pump unit only is C00054979 at £25.27 list, it’s called a “pump cover” for some reason 😕
    Are you absolutely sure about that Dave, I had to fit a pump to a similar Hotpoint/Indesit machine recently and the pump assy was not designed to be removable from the motor as far as I could see.?
    I changed that one for a pump leak and thought I would try to remove the pump and salvage a perfectly good motor but it wasn’t worth the effort so I binned it.
    #183075
    Dave_Conway
    Re: hotpoint fdw60g
    iadom wrote:Are you absolutely sure about that Dave
    Position 33 on the diagram, seperate pump. I’ve not fitted one so the feasability of it I’m not sure of course 😉
    #183076
    Re: hotpoint fdw60g
    I can see item 33 but as it said ‘pump cover’ I ordered and fitted complete pump, I tried to remove the pump body from the displaced unit without doing it severe damage but was unable to do so.
    #183077
    robbo1973
    Re: hotpoint fdw60g
    thanx for the help. the pump unit comes apart pretty easy 2 screws on the side and 13mm nut on impellor and slotted driver other end. the big nut is not part of the lower spray arm you push the sump up from the underside and this locking nut thing from the inside.calling it a nut might be a bit misleading as it is circular with four locating slots, a bit hard to describe but a bit similair to the way the newer zan square askolls fit approx quarter of a turn. the only reason i was asking is the cust says she had not tampered with it so i was not sure how it came loose 👿 .
