Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › hotpoint fdw60g
- This topic has 9 replies, 4 voices, and was last updated 17 years, 9 months ago by
dom999.
June 23, 2008 at 9:41 pm #37589
dom999
Participanthi guys, any help would be appreciated.
had error light flashing on d/w (delicates/number6), advised by hotpoint that it was heating time out. checked element reading showed 26 ohms, checked voltage at terminal plug reading 240v, could find no reset, but with voltage at plug this would not make sense anyway. am i just being thick or have i missed something else??? any advice would be really appreciated, thanks.June 23, 2008 at 10:26 pm #255705Penguin45
ParticipantRe: hotpoint fdw60g
Are you actually getting any heat? 6 is usually a sensor problem, although a burnt solder joint on the pcb can allow voltage through, but not a lot of current.
This is a public forum, so I have to tell you not to live test – very dangerous.
June 23, 2008 at 10:26 pm #255706helo_75
Participanthave you actually tried the dishwasher again?
wouldnt be the first time the machine works on the next attempt… the pcb’s on all indesit / hotpoint appliances are notoriously temperamental and un reliable
June 23, 2008 at 10:28 pm #255707Penguin45
:waving: Evenin’ Helo…….
:p45:
June 24, 2008 at 12:41 am #255708helo_75
Participanthow ya doin mr p?
June 24, 2008 at 7:48 am #255709dom999
thanks for reply,
getting no heat unfortunately, when m/c is filled and pressure switch has activated, the plug on the element is showing 240v, checked on both wires to earth and accross the 2 said wires, but when checked with the clamp on its showing no current draw. whats more confusing is the element coil is showing 26 ohms resistance. had a look at the board but all connections ‘look’ ok. incidently i am a service technician for commercial catering equipment, but not much experience with hotpoint etc….so it could be the board.June 24, 2008 at 6:18 pm #255710dom999
checking over again, penguin 45 mentioned bad solder on the pcb, any one i should check in particular, im assuming its the pink wire spade connector????…….not much hair left now…..
June 29, 2008 at 5:33 pm #255711dom999
does anybody know of a supplier for used/recon boards for fdw60g dishwasher, all problems seem to lead to this, thanks.
June 29, 2008 at 10:07 pm #255712iadom
ModeratorRe: hotpoint fdw60g
dom999 wrote:does anybody know of a supplier for used/recon boards for fdw60g dishwasher, all problems seem to lead to this, thanks.
Why bother, two different PCB’s both around £25.00 ex vat. It would be uneconomic for anyone to refurb these boards.
We would need full serial number to ID the correct part number.
August 29, 2008 at 6:30 pm #255713dom999
I finally got round to getting the board from the ukwg shop site, excellent price and delivery, best of all is the machine works. thanks for the help and will recommend to all. dom. 😀 😀 😀
