Hotpoint FDW60P
  • #42677
    sami786 wrote:[hi im new to this. i have hotpoint fdw60p dishwasher. when i put it on it starts then half way thru the delicates light start flashing is this an error code. nothing in the manual. plz help. machine purchased aug 2007. many thanx
    Created a new topic for you Sami, as your machine and problem is not related to the thread you tagged onto.
    Penguin45,
    Moderator.
    #274407
    Re: Hotpoint FDW60P
    Error is fault code 8 – no heat detected in the time allowed. This is usually heater failure, but can also be caused by computer failure. If you do actually have heat in the machine, it is possible that the temperature sensor has become detached from the door inner.
    Power of if you intend to investigate this yourself.
    sami786
    Re: Hotpoint FDW60P
    Penguin45 wrote:Error is fault code 8 – no heat detected in the time allowed. This is usually heater failure, but can also be caused by computer failure. If you do actually have heat in the machine, it is possible that the temperature sensor has become detached from the door inner.
    Penguin45. any suggestions as to wot i shud do????????????/
    #274409
    Re: Hotpoint FDW60P
    Options:
    1/ Get out the screwdrivers and the test meter and test the heater.
    2/ Use the repairs@ link on the left to find you local independent repairer.
    3/ Pay The Indesit Company £100 and get all your parts for free.
