hotpoint FDW60T d/w
  • #22042
    hilly
    can anyone help me pls? the eco and prewash lights are flashing and the circulation pump is continuously going when i turn the appliance on without selecting a programme im guessing it will be a replacement pcb
    job?
    thanks paul
    #193493
    Re: hotpoint FDW60T d/w
    Neons 3+5 indicate blocked filters. Mesh plate,filter or microfilter, pressure sensor,pressure switch or faulty circulation pump.
    Information is in the Known Error codes thread, lower down, page #3 😉
    hilly
    cheers iadom, filters all clear and ive disconnected the pressure switch blown down it but nothing changes, ive not done much an these newer htpts its just baffled me that the circ motor was continuously going im going back this week for another bash, any advice b4 i go would be appreciated.
    thanks paul
    #193495
    It does list a module fault as a possible cause of this error message as well. 😥
    hilly
    been back to see this one i took a pcb just incase but it didnt cure the problem circ motor still contiuously running ive checked all hoses just incase of blockages but all clear any more ideas cos im baffled 😕 😛
    cheers paul
    #193497
    Strange, I have e-mailed you the schematic, it may help you trace where the feed is coming from, 😕
