Hotpoint FDW70G A10 Fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint FDW70G A10 Fault
  • #60701
    leosaphira
    Hi all..
    Can anyone advise me how to go abouts finding and sorting out the problem part for this fault code as I will be dammed in paying out £110 odd to hotpoint to come out and work on the machine.
    Anyhow, its a 2 year old Hotpoint FDW70G Model from mother (she replaced stright away 6 months ago with the fault showing) rather me taking it to the tip I’ve rescued it and its been sitting in the kitchen for the last 6 months.
    It fills up with water and just “before” it starts a wash, A10 fault flashs on the screen and you can hear water being dumped out of the system into the drain.
    Some internet searches are showing it as a heater fault and others are saying fill valve fault?
    What would it be please and the solution to get her working again 🙂
    Many Thanks
    LS 🙂
    #343281
    It’s a problem on the heater circuit but it doesn’t specify where. Could be an element or stats.
    The element is a fairly common problem though and it’s available HERE
    HTH
    washtronics
    Re: Hotpoint FDW70G A10 Fault
    yes the heaters do go on the hotpoint, sometimes the toc cuts out after about 10-20 mins because of limescale build up, change the heater-you should clear the fault
