Hotpoint FDW75 dishwasher.
  • #32148
    aqualectric
    Attended this silver – coloured heap last week and found that the base was flooded. Cause – blow hole in the outlet hose. The hole looked as if it had been melted with a soldering iron tip from the inside – neat and raised. 😕
    OK, thinks I, easy job; new hose fitted, everyone’s happy.
    Called back today and the new hose is holed exactly as before and flooding over the components, blowing trip…… 👿
    The hole is where the outlet hose leaves the pump and just after the rubber connection cuff. It is the closest part to the heater; but when I fitted the new hose I made every effort to get it as far away as possible from the heat source. I assume it is the heater melting the hose; what I can’t understand is why it is a pinhole with no surrounding damage.
    Anyone else had this problem? There is little room to reposition the hose as it is already tight as it is. My only option now seems to be to cover it in a foil sleeve. But that’s not it’s original design………:?
    Any thoughts?
    Steve.
    #233813
    grendel
    Re: Hotpoint FDW75 dishwasher.
    Original Design thats a laugh…we all know (or should do) that Indesit design leaves alot to be desired.. Personally what I do with these is seal with debore then tape them up and twist as best as poss from heater, normally able to get it far enough away, If not a bit of closure plate tape round aswell wouldnt hurt….
    #233814
    aqualectric
    Cheers for that Grendel!!
    I’ve fitted a new hose and with the base off, managed to twist it far away from the heater.
    Ironically, the heater is now down to earth and it looks like I can’t salvage it…….. 😈 Absolute garbage!!
    Steve.
