hotpoint fdw80 al10 error
  • #43959
    hilly
    htpt fdw80g 31701466
    this model is showing al10, i realise this relates to a heater fault,
    it heats on wash ok but when it gets to 21mins it beeps and shows al10
    any ideas pls b4 i order a module to try
    thanks paul
    #279220
    sparkys
    Re: hotpoint fdw80 al10 error
    check pump for blockage, also you will find water inside the pump impellor, clear, grease and reseal
    #279221
    hilly
    sparkys wrote:check pump for blockage, also you will find water inside the pump impellor, clear, grease and reseal
    thanks for the reply, are you talking about the drain punp or circulation pump?
    paul
    #279222
    hilly
    any clues? im going back on monday and would like to be armed with as much info as poss. 😉
    thanks paul
    #279223
    sparkys
    drain pump!
    #279224
    sparkys wrote: also you will find water inside the pump impellor, clear, grease and reseal
    I have to be perfectly honest, I have no idea what this is about. 😕
    Water ‘inside’ a pump impellor. ❓
    From the manual.
    AL10.
    Open circuit in heater circuit.
    Check heater and heater TOC.
    Check pressure switch 11-14 for O/c.
    Check wiring connections between heater, pressure switch & module card.
    If all OK, change the module.
    NOTE.
    Is AL10 displays intermittantly..if the spray arms are not able to rotate correctly the heater will overheat and the cut out will operate displaying AL10.
    #279225
    sparkys
    As we are all trying to help – i will hold back on any further information as this could confused the situation, but would like to know the outcome.
    Sparkys
    #279226
    Please don’t misunderstand my reply, I am in no way trying to undermine your contribution, I am just puzzled as to your mention of ‘finding water inside the pump impellor, clear, grease and reseal’.
    I have removed countless drain pumps from these Indesit heaps of junk, they do block up for fun but have never had to grease or reseal. Just remove the blockage and refit.
    Also have never had a blocked drain pump throwing up AL10. That doesn’t mean to say it couldn’t happen, they are so flaky that anything is possible.
    The answer is out there…. 8) 😀
    I think sparkys is talking about pulling out the rotor from the pump body and cleaning it. I think this is possible with some but not all magnet pumps. I usually replace pump if it’s all gunged up in there.
    I did once use a second hand rotor assembly from my toolbag because I didn’t have a bayonet fit Askoll with me and it’s been going strong for 3 years now 😯 .
    Mike.
    #279228
    hilly
    thanks for replies i will let you know the outcome 😉
    thanks again paul
    #279229
    leavemetogetonwithit wrote:I think sparkys is talking about pulling out the rotor from the pump body and cleaning it
    Ah, I see. 😳
    A blocked or faulty pump shouldn’t give AL10 though. 😕
    hilly
    does the module for these come ready to fit or do they have to be programmed? ive just been looking on hotpoints site and they list a blank eprom as well as a module
    thanks paul
    #279231
    The larger module in the base is an eeprom/smart card job. 😥
    #279232
    hilly
    cheers jim 😥
