I tried searching for this fault on the forum to see whether the main PCB in base or the display module is the most likely culprit.
I have power into main module but the D/W is otherwise dead.
Thanks, Simon.
check the motor and heater for earth leakage as it locks out the 100bit module also check for sticky console buttons as this also locks out the module.
