Hi all ive looked at the codes for al10 which this machine is bringing up heating etc,but the heater is ok and power getting to heater.As far as i can gather it is getting to hot as customer said it smelled really hot do i need a new board or can the temperature sensor be changed. Any info would help.thanks.
ok sounds like the board then ,i sold this to them second hand a few months back for £100 so it aint gona be worth fixing. Its a pain as i only went there in the first place to change the top spray arm fixing nut as i did that it then melted a hole in the drain hose so changed that then this happened,what a pain.
