Hi, ive got a problem with the micoswitch which has burnt out – door was showing as being open when it was not.
IVe ordered a replacment microswitch but the connecting cable block on the wiring loom is also showing signs of being burnt, 😕 2 questions can this be repalced on its own without having to get a compleate new wiring loom(80 quid) and do you think it would still work once the micro switch is replaced, the connector seems to be intact?
