Hotpoint FDW85,advice.
  • #35206
    effzedarr
    Went to one of these m/cs today ,flashing up AL10= heater or heater circuit.Turns out its the heater but when i return to fit the heater do i need to reset the dishwasher, with it been a fancy LCD type thing? If so how do you go about it? Or is it just fit & go? Other numbers are LS 12-EVO 3 if that means owt to anybody..
    Many thanx & regards Chris..
    #245509
    Re: Hotpoint FDW85,advice.
    To reset after a fault, press and hold the Start/Reset button until you get the dashes in the display.
    When a 100 bit card is first fitted it may go into a factory test cycle.
    To eliminate.
    * Switch ON with door closed.
    * Wait for the Test cycle to start up (two leds will start to flash)
    *Switch OFF the machine with the door still closed and wait for 15 seconds.
    *Switch ON the machine.
    Note. All the above should be carried out quickly and the 15 seconds must be exact.
    The manual tells you to turn the selector knob to reset but as the machine is all push button I have not yet worked that one out. :rolls: 😆
    effzedarr
    Many thanx Jim!
    Chris…
