Hi, I trust someone can help. As above dishwasher starts cycle, i can hear short drain, Fills OK, Washer pump works, soap is released on some cycles, but machine stops after about 4 minutes with the F13 error code. When code flashes machines completes a drain cycle and the water is cold. However a prewash cycle seems to work OK. F13 error code indicates control module or wiring? But I am thinking it may be a faulty heater or thermostat as the water does not warm up.
I look forward to any suggestions or ideas.
Regards
